C 60 display issue
Yasir Vistro
Hi All
i have C 60 with 3 display ...  (1) HDMI (LCD)  2nd Display on  (DVI )   and 3 composit on Prijector ...  i receive selfview in  Small window on Projector.
Picture is attached .
appriciate your quick responce .
Yasir Vistro
Yasir Vistro
Tomonori Taniguchi
Looks like monitor role for composite out are set to “First”.
Have you modify the layout which you should able to change selfview to full screen.
You can change monitor role to different configuration by “xConfiguration Video Output Composite MonitorRole:”.
Also Cisco TC Console application help you to modify the display style and display source.
TC Console application and information is avaliabl from http://developer.cisco.com/web/telepresence-developer/home.
Hi Yasir,
When you use analog composite output from codec the you will get one video streame from codec , Photograph is showing one vide stream ( self view) This is expected beheviour.
If you de activate self view then you should get fard end on display.
Kind regards,
Dharmmesh
