C20 won't pair
daperez2
Hi all,
We have a C20 installed in our office, it can make calls and everything just fine. We want to use the Touch to manipulate it, but even thouhg it recognizes the codec it asks for a user/password. We have the admin credentials to access the GUI and also a user account, we know they are OK because we can enter the GUI just fine.
But the Touch won't recognize those credentials and it will not pair with the codec. We've tried a hundred times...and it just won't pass through that request.
Any ideas?
David
2 Accepted Solutions
I do not see any sshd related logins. I do not think  the touch tries to connect. Hard to see what is going on.
Are there any current logfiles of the C20 to look at ?
It seems that it is off.
*c xConfiguration NetworkServices SSH Mode: Off
It also seems it needs to be on.
https://supportforums.cisco.com/thread/2151951
I would enable SSH in the GUI and try paring again.
11 Replies 11
Ravi Yadav
Level 4
Level 4
Hi David,
Perform a factory reset to the touch panel.
Tap and hold the exclamation mark fir 15 seconds and as soon as it lights up hit the mute buttin twice. It will rset the touch pad.
Try logging again. Let us kniw the results
Ravi kr.
Sent from Cisco Technical Support Android App
Hi Ravi,
Thanks for the tip. I already knew the trick and tried it several times , it does not matter. I have also made sure that the codec is on pairing mode.
I am not sure if we should do everything in a specific order, I mean, turning the codec on, then resetting the Touch and so forth.
David
Perhaps an easy way to check is to enable audit logging.
In the file /var/log/audit.log I see this for a failed pairing due to wrong password and a good pairing :
Mar 30 07:45:12 (none) sshd[15995]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=ams-dderidde-8917.cisco.com  user=admin
Mar 30 07:45:36 (none) sshd[16001]: pam_unix(sshd:session): session opened for user admin by (uid=0)
Mar 30 07:45:36 (none) sshd[16001]: pam_unix(sshd:session): session closed for user admin
Mar 30 07:45:37 (none) sshd[16007]: pam_unix(sshd:session): session opened for user admin by (uid=0)
Mar 30 07:45:37 (none) sshd[16007]: pam_unix(sshd:session): session closed for user admin
Mar 30 07:45:38 (none) sshd[16012]: pam_unix(sshd:session): session opened for user admin by (uid=0)
To enable the audit do :
xConfiguration Security Audit Server Address: ""
xConfiguration Security Audit Server Port: 514
xConfiguration Security Audit OnError Action: Ignore
xConfiguration Security Audit Logging Mode: Internal
And then reboot the codec for enabling the audit feature.
What do you see then in the audit log ?
Ravi Yadav
Level 4
Level 4
Hi David,
As you already performed the factory reset . Now logs will gice us better information.
As Danny referenced the exact logs which can confirm one of the common issues happening.
Hi Danny and Ravi,
This is the output so far:
Apr  1 14:41:34 (none) audit: auditing started
Apr  1 08:42:04 (none) login: pam_unix(login:session): session opened for user admin by (uid=0)
Apr  1 08:42:04 (none) login: LOGIN ON pts/0 BY admin FROM 172.18.43.37
Apr  1 08:42:04 (none) login: pam_unix(login:session): session closed for user admin
Apr  1 08:42:52 (none) main: User (0) successfully executed command '/Audio/Sound/Stop' from .
Apr  1 08:42:53 (none) main: User (0) successfully executed command '/Audio/Microphones/Unmute' from .
Apr  1 08:42:53 (none) main: User (0) successfully executed command '/Bookings/List' from .
Apr  1 08:44:41 (none) login: pam_unix(login:session): session opened for user admin by (uid=0)
Apr  1 08:44:41 (none) login: LOGIN ON pts/0 BY admin FROM 172.18.43.37
Apr  1 08:44:57 (none) userdb: New session for user admin from 172.18.43.37 on web.
Apr  1 08:51:49 (none) main: User (0) successfully executed command '/CamCtrlPip Mode: On' from .
Apr  1 08:51:53 (none) main: User (0) successfully executed command '/CamCtrlPip Mode: Off' from .
Apr  1 08:52:00 (none) main: User (0) successfully executed command '/SystemUnit/MenuPassword/Validate Password: Input Hidden' from .
Apr  1 08:52:02 (none) main: User (0) successfully changed configuration '/Network[1]/IPStack' to 'IPv4' from .
Not sure what it could mean, I guess the second line (bottom to top) is telling me that it did not validate the password, do you have any suggestion?
Thanks a lot,
David
Is SSH required to be enabled by the Touch?  If so has it been confimed that SSH is enabled on the C20?
Not sure if SSH is required, I know for a fact that I can only Telnet it, I can't connect through SSH. I have the xstatus and xconfig.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2013.04.01 08:22:28 =~=~=~=~=~=~=~=~=~=~=~=
login: admin
Password:
Welcome to
TANDBERG Codec Release TC5.1.5.297625
SW Release Date: 2012-11-16
OK
xstatus
*s Audio Microphones Mute: Off
*s Audio Volume: 90
*s Camera 1 Connected: False
*s Camera 1 HardwareID: ""
*s Camera 1 Manufacturer: ""
*s Camera 1 Model: ""
*s Camera 1 SoftwareID: ""
*s Camera 1 SerialNumber: ""
*s Camera 1 IpAddress: ""
*s Camera 1 MacAddress: ""
*s Camera 1 Position Pan: 0
*s Camera 1 Position Tilt: 0
*s Camera 1 Position Zoom: 16
*s Camera 1 Position Focus: 4000
*s Camera 1 Capabilities Options: ""
*s Camera 1 Flip: "Off"
*s Conference Presentation Mode: Off
*s Conference Presentation Protocol: ""
*s Conference Presentation Resolution Height: 0
*s Conference Presentation Resolution Width: 0
*s Conference Presentation SiteId: 0
*s Conference Presentation LocalSource: 0
*s Conference Multipoint Mode: "Off"
*s Conference DoNotDisturb: Inactive
*s Experimental Audio Input Connectors Microphone 1 Activity: False
*s Experimental Audio Input Connectors Microphone 2 Activity: False
*s Experimental Audio Input Connectors Line 1 Activity: False
*s Experimental Audio Input Connectors Line 2 Activity: False
*s HttpFeedback 1 URL: ""
*s HttpFeedback 1 Expression: ""
*s HttpFeedback 2 URL: ""
*s HttpFeedback 2 Expression: ""
*s HttpFeedback 3 URL: ""
*s HttpFeedback 3 Expression: ""
*s HttpFeedback 4 URL: ""
*s HttpFeedback 4 Expression: ""
*s Network 1 Ethernet MacAddress: "00:50:60:0D:C0:E5"
*s Network 1 Ethernet Speed: "100full"
*s Network 1 IPv4 Address: "10.18.43.100"
*s Network 1 IPv4 SubnetMask: ""
*s Network 1 IPv4 Gateway: ""
*s Network 1 IPv4 DNS Domain Name: "ad.hbfuller.com"
*s Network 1 IPv4 DNS Server 1 Address: "172.18.13.9"
*s Network 1 IPv4 DNS Server 2 Address: "172.16.13.105"
*s Network 1 IPv4 DNS Server 3 Address: ""
*s Network 1 IPv4 DNS Server 4 Address: ""
*s Network 1 IPv4 DNS Server 5 Address: ""
*s Network 1 IPv6 Address: ""
*s Network 1 IPv6 Gateway: ""
*s Network 1 MTU: 1500
*s Network 1 VLAN Voice VlanId: "200"
*s Preset 1 Defined: False
*s Preset 1 Type: All
*s Preset 1 Description: ""
*s Preset 2 Defined: False
*s Preset 2 Type: All
*s Preset 2 Description: ""
*s Preset 3 Defined: False
*s Preset 3 Type: All
*s Preset 3 Description: ""
*s Preset 4 Defined: False
*s Preset 4 Type: All
*s Preset 4 Description: ""
*s Preset 5 Defined: False
*s Preset 5 Type: All
*s Preset 5 Description: ""
*s Preset 6 Defined: False
*s Preset 6 Type: All
*s Preset 6 Description: ""
*s Preset 7 Defined: False
*s Preset 7 Type: All
*s Preset 7 Description: ""
*s Preset 8 Defined: False
*s Preset 8 Type: All
*s Preset 8 Description: ""
*s Preset 9 Defined: False
*s Preset 9 Type: All
*s Preset 9 Description: ""
*s Preset 10 Defined: False
*s Preset 10 Type: All
*s Preset 10 Description: ""
*s Preset 11 Defined: False
*s Preset 11 Type: All
*s Preset 11 Description: ""
*s Preset 12 Defined: False
*s Preset 12 Type: All
*s Preset 12 Description: ""
*s Preset 13 Defined: False
*s Preset 13 Type: All
*s Preset 13 Description: ""
*s Preset 14 Defined: False
*s Preset 14 Type: All
*s Preset 14 Description: ""
*s Preset 15 Defined: False
*s Preset 15 Type: All
*s Preset 15 Description: ""
*s Provisioning Status: Idle
*s Provisioning Reason: ""
*s Provisioning Software UpgradeStatus SessionId: ""
*s Provisioning Software UpgradeStatus LastChange: ""
*s Provisioning Software UpgradeStatus Status:
*s Provisioning Software UpgradeStatus Phase:
*s Provisioning Software UpgradeStatus Message: ""
*s Provisioning Software UpgradeStatus VersionId: ""
*s Provisioning Software UpgradeStatus URL: ""
*s Provisioning Software Current VersionId: ""
*s Provisioning Software Current URL: ""
*s Provisioning Software Current CompletedAt: ""
*s Security FIPS Mode: Off
*s SIP Proxy 1 Status: Active
*s SIP Proxy 1 Address: "10.16.8.180"
*s SIP Proxy 1 Secure: False
*s SIP Proxy 1 Verified: False
*s SIP Registration 1 Status: Registered
*s SIP Registration 1 Reason: ""
*s SIP Registration 1 URI: "7590@10.16.8.180"
*s SIP Registration 1 Authentication: Off
*s SIP Profile 1 Proxy 1 Status: Active
*s SIP Profile 1 Proxy 1 Address: "10.16.8.180"
*s SIP Profile 1 Secure: False
*s SIP Profile 1 Verified: False
*s SIP Profile 1 Authentication: Off
*s SIP Profile 1 Registration 1 Status: Registered
*s SIP Profile 1 Registration 1 Reason: ""
*s SIP Profile 1 Registration 1 URI: "7590@10.16.8.180"
*s Standby Active: On
*s SystemUnit ProductType: "TANDBERG Codec"
*s SystemUnit ProductId: "TANDBERG Codec C20"
*s SystemUnit ProductPlatform: "C20"
*s SystemUnit Uptime: 318465
*s SystemUnit Software Application: "Endpoint"
*s SystemUnit Software Version: "TC5.1.5.297625"
*s SystemUnit Software Name: "s52000"
*s SystemUnit Software ReleaseDate: "2012-11-16"
*s SystemUnit Software MaxVideoCalls: 1
*s SystemUnit Software MaxAudioCalls: 2
*s SystemUnit Software ReleaseKey: "true"
*s SystemUnit Software OptionKeys NaturalPresenter: "true"
*s SystemUnit Software OptionKeys PremiumResolution: "false"
*s SystemUnit Software OptionKeys HighDefinition: "true"
*s SystemUnit Software OptionKeys DualDisplay: "false"
*s SystemUnit Hardware Module SerialNumber: "F1AN06F00273"
*s SystemUnit Hardware Module Identifier: "C1"
*s SystemUnit Hardware Module CompatibilityLevel: "1"
*s SystemUnit Hardware MainBoard SerialNumber: "PB0702529"
*s SystemUnit Hardware MainBoard Identifier: "101551-4 [00]"
*s SystemUnit Hardware BootSoftware: "U-Boot 2010.06-108"
*s SystemUnit Hardware MonitoringSoftware: "45"
*s SystemUnit Hardware Monitoring Fan 1 Status: "locked on 4320 rpm"
*s SystemUnit Hardware Monitoring Fan 2 Status: "locked on 4320 rpm"
*s SystemUnit Hardware Temperature: "58.0"
*s SystemUnit State System: Initialized
*s SystemUnit State MaxNumberOfCalls: 2
*s SystemUnit State MaxNumberOfActiveCalls: 2
*s SystemUnit State NumberOfActiveCalls: 0
*s SystemUnit State NumberOfSuspendedCalls: 0
*s SystemUnit State NumberOfInProgressCalls: 0
*s SystemUnit State Subsystem Application: Initialized
*s SystemUnit ContactInfo: "7590@10.16.8.180"
*s Time ZoneOlson: America/Managua
*s Video Input LastConnectedSource: 0
*s Video Input Source 1 Resolution Height: 0
*s Video Input Source 1 Resolution Width: 0
*s Video Input Source 1 Resolution RefreshRate: 0
*s Video Input Source 1 Resolution FormatType: Unknown
*s Video Input Source 1 Resolution FormatStatus: Error
*s Video Input Source 2 Resolution Height: 0
*s Video Input Source 2 Resolution Width: 0
*s Video Input Source 2 Resolution RefreshRate: 0
*s Video Input Source 2 Resolution FormatType: Unknown
*s Video Input Source 2 Resolution FormatStatus: Error
*s Video Input HDMI 1 Connected: False
*s Video Input HDMI 1 SignalState: Unknown
*s Video Input DVI 2 Connected: False
*s Video Input DVI 2 SignalState: Unknown
*s Video Output HDMI 1 Resolution Height: 480
*s Video Output HDMI 1 Resolution Width: 720
*s Video Output HDMI 1 Resolution RefreshRate: 60
*s Video Output HDMI 2 Resolution Height: 720
*s Video Output HDMI 2 Resolution Width: 1280
*s Video Output HDMI 2 Resolution RefreshRate: 60
*s Video Layout PresentationView: Default
*s Video Layout Site 1 Output 1 FamilyName: "fullscreen"
*s Video Layout Site 1 Output 1 FullFamilyName: "fullscreen-local-single-camctrl"
*s Video Layout Site 1 Output 1 GraphicName: "1"
*s Video Layout Site 1 Output 1 Frame 1 PositionX: 0
*s Video Layout Site 1 Output 1 Frame 1 PositionY: 0
*s Video Layout Site 1 Output 1 Frame 1 Width: 10000
*s Video Layout Site 1 Output 1 Frame 1 Height: 10000
*s Video Layout Site 1 Output 1 Frame 1 Layer: 1
*s Video Layout Site 1 Output 1 Frame 1 VideoSourceType: "graphic"
*s Video Layout Site 1 Output 1 Frame 1 VideoSourceId: 0
*s Video Layout Site 1 Output 1 Frame 1 InputNumber: 0
*s Video Layout Site 1 Output 1 Frame 1 Filename: "/apps/posters/waves.png"
*s Video Layout Site 1 Output 1 Frame 2 PositionX: 0
*s Video Layout Site 1 Output 1 Frame 2 PositionY: 0
*s Video Layout Site 1 Output 1 Frame 2 Width: 10000
*s Video Layout Site 1 Output 1 Frame 2 Height: 10000
*s Video Layout Site 1 Output 1 Frame 2 Layer: 0
*s Video Layout Site 1 Output 1 Frame 2 VideoSourceType: "site"
*s Video Layout Site 1 Output 1 Frame 2 VideoSourceId: 1
*s Video Layout Site 1 Output 1 Frame 2 InputNumber: 0
*s Video Layout Site 1 Output 1 Frame 2 Filename: ""
** end
OK
xconfig
*c xConfiguration Audio Microphones Mute Enabled: True
*c xConfiguration Audio Volume: 90
*c xConfiguration Audio SoundsAndAlerts RingVolume: 50
*c xConfiguration Audio SoundsAndAlerts RingTone: Marbles
*c xConfiguration Audio SoundsAndAlerts KeyTones Mode: On
*c xConfiguration Cameras PowerLine Frequency: Auto
*c xConfiguration Cameras Camera 1 Brightness Mode: Auto
*c xConfiguration Cameras Camera 1 Brightness Level: 1
*c xConfiguration Cameras Camera 1 Whitebalance Mode: Auto
*c xConfiguration Cameras Camera 1 Whitebalance Level: 1
*c xConfiguration Cameras Camera 1 Focus Mode: Auto
*c xConfiguration Cameras Camera 1 Backlight: Off
*c xConfiguration Cameras Camera 1 Mirror: Auto
*c xConfiguration Cameras Camera 1 Flip: Auto
*c xConfiguration Cameras Camera 1 DHCP: Off
*c xConfiguration Cameras Camera 1 Gamma Mode: Auto
*c xConfiguration Cameras Camera 1 Gamma Level: 0
*c xConfiguration Cameras Camera 1 IrSensor: On
*c xConfiguration Conference 1 AutoAnswer Mode: Off
*c xConfiguration Conference 1 AutoAnswer Mute: Off
*c xConfiguration Conference 1 AutoAnswer Delay: 0
*c xConfiguration Conference 1 MicUnmuteOnDisconnect Mode: On
*c xConfiguration Conference 1 DoNotDisturb Mode: Off
*c xConfiguration Conference 1 FarEndControl Mode: On
*c xConfiguration Conference 1 FarEndControl SignalCapability: On
*c xConfiguration Conference 1 Encryption Mode: BestEffort
*c xConfiguration Conference 1 DefaultCall Protocol: Sip
*c xConfiguration Conference 1 DefaultCall Rate: 768
*c xConfiguration Conference 1 MaxTransmitCallRate: 6000
*c xConfiguration Conference 1 MaxReceiveCallRate: 6000
*c xConfiguration Conference 1 VideoBandwidth Mode: Dynamic
*c xConfiguration Conference 1 VideoBandwidth MainChannel Weight: 5
*c xConfiguration Conference 1 VideoBandwidth PresentationChannel Weight: 5
*c xConfiguration Conference 1 PacketLossResilience Mode: On
*c xConfiguration Conference 1 Presentation Policy: LocalRemote
*c xConfiguration Conference 1 Multipoint Mode: Auto
*c xConfiguration Conference 1 IncomingMultisiteCall Mode: Allow
*c xConfiguration Experimental Conference 1 ReceiverBasedDownspeeding: On
*c xConfiguration Experimental Conference 1 PacketLossResilience ForwardErrorCorrection: On
*c xConfiguration Experimental Conference 1 PacketLossResilience RateAdaption: On
*c xConfiguration Experimental Conference 1 Multistream Mode: Off
*c xConfiguration Experimental Conference 1 Multistream InputCount: 2
*c xConfiguration Experimental Conference 1 Multistream OutputCount: 1
*c xConfiguration Experimental Conference 1 Multistream Stream 1 Source: 1
*c xConfiguration Experimental Conference 1 Multistream Stream 2 Source: 1
*c xConfiguration Experimental Conference 1 Multistream Stream 3 Source: 1
*c xConfiguration Experimental Conference 1 Multistream Stream 4 Source: 1
*c xConfiguration Experimental CapsetFilter: ""
*c xConfiguration Experimental CapsetReduction: Auto
*c xConfiguration Experimental NetworkServices UPnP Mode: On
*c xConfiguration Experimental NetworkServices UPnP Timeout: 600
*c xConfiguration Experimental SystemUnit MenuType: Full
*c xConfiguration Experimental SystemUnit SoftwareUpgrade RequireAuthentication: On
*c xConfiguration Experimental SystemUnit CrashReporting Mode: Off
*c xConfiguration Experimental SystemUnit CrashReporting URI: ""
*c xConfiguration Experimental CTMSSupport Mode: On
*c xConfiguration Experimental CustomSoftbuttons HoldResume: Off
*c xConfiguration Experimental CustomSoftbuttons State 1 SoftButton 1 Type: NotSet
*c xConfiguration Experimental CustomSoftbuttons State 1 SoftButton 1 Value: ""
*c xConfiguration Experimental CustomSoftbuttons State 1 SoftButton 2 Type: NotSet
*c xConfiguration Experimental CustomSoftbuttons State 1 SoftButton 2 Value: ""
*c xConfiguration Experimental CustomSoftbuttons State 1 SoftButton 3 Type: NotSet
*c xConfiguration Experimental CustomSoftbuttons State 1 SoftButton 3 Value: ""
*c xConfiguration Experimental CustomSoftbuttons State 1 SoftButton 4 Type: NotSet
*c xConfiguration Experimental CustomSoftbuttons State 1 SoftButton 4 Value: ""
*c xConfiguration Experimental CustomSoftbuttons State 1 SoftButton 5 Type: NotSet
*c xConfiguration Experimental CustomSoftbuttons State 1 SoftButton 5 Value: ""
*c xConfiguration Experimental CustomSoftbuttons State 2 SoftButton 1 Type: NotSet
*c xConfiguration Experimental CustomSoftbuttons State 2 SoftButton 1 Value: ""
*c xConfiguration Experimental CustomSoftbuttons State 2 SoftButton 2 Type: NotSet
*c xConfiguration Experimental CustomSoftbuttons State 2 SoftButton 2 Value: ""
*c xConfiguration Experimental CustomSoftbuttons State 2 SoftButton 3 Type: NotSet
*c xConfiguration Experimental CustomSoftbuttons State 2 SoftButton 3 Value: ""
*c xConfiguration Experimental CustomSoftbuttons State 2 SoftButton 4 Type: NotSet
*c xConfiguration Experimental CustomSoftbuttons State 2 SoftButton 4 Value: ""
*c xConfiguration Experimental CustomSoftbuttons State 2 SoftButton 5 Type: NotSet
*c xConfiguration Experimental CustomSoftbuttons State 2 SoftButton 5 Value: ""
*c xConfiguration Experimental Audio Panning Mode: Off
*c xConfiguration Experimental Audio Panning MaxAngle: 60
*c xConfiguration Experimental Audio Panning MonitorLeft: 1
*c xConfiguration Experimental Audio Panning MonitorRight: 1
*c xConfiguration Experimental Audio EcReferenceDelay: 0
*c xConfiguration FacilityService Service 1 Type: Helpdesk
*c xConfiguration FacilityService Service 1 Name: ""
*c xConfiguration FacilityService Service 1 Number: ""
*c xConfiguration FacilityService Service 1 CallType: Video
*c xConfiguration FacilityService Service 2 Type: Helpdesk
*c xConfiguration FacilityService Service 2 Name: ""
*c xConfiguration FacilityService Service 2 Number: ""
*c xConfiguration FacilityService Service 2 CallType: Video
*c xConfiguration FacilityService Service 3 Type: Helpdesk
*c xConfiguration FacilityService Service 3 Name: ""
*c xConfiguration FacilityService Service 3 Number: ""
*c xConfiguration FacilityService Service 3 CallType: Video
*c xConfiguration FacilityService Service 4 Type: Helpdesk
*c xConfiguration FacilityService Service 4 Name: ""
*c xConfiguration FacilityService Service 4 Number: ""
*c xConfiguration FacilityService Service 4 CallType: Video
*c xConfiguration FacilityService Service 5 Type: Helpdesk
*c xConfiguration FacilityService Service 5 Name: ""
*c xConfiguration FacilityService Service 5 Number: ""
*c xConfiguration FacilityService Service 5 CallType: Video
*c xConfiguration H323 NAT Mode: Off
*c xConfiguration H323 NAT Address: ""
*c xConfiguration H323 Profile 1 H323Alias ID: ""
*c xConfiguration H323 Profile 1 H323Alias E164: ""
*c xConfiguration H323 Profile 1 PortAllocation: Dynamic
*c xConfiguration H323 Profile 1 CallSetup Mode: Gatekeeper
*c xConfiguration H323 Profile 1 Gatekeeper Address: ""
*c xConfiguration H323 Profile 1 Gatekeeper Discovery: Manual
*c xConfiguration H323 Profile 1 Authentication LoginName: ""
*c xConfiguration H323 Profile 1 Authentication Password: ""
*c xConfiguration H323 Profile 1 Authentication Mode: Off
*c xConfiguration Network 1 VLAN Voice Mode: Auto
*c xConfiguration Network 1 VLAN Voice VlanId: 1
*c xConfiguration Network 1 Speed: Auto
*c xConfiguration Network 1 Assignment: DHCP
*c xConfiguration Network 1 IPStack: IPv4
*c xConfiguration Network 1 IPv6 Address: ""
*c xConfiguration Network 1 IPv6 Gateway: ""
*c xConfiguration Network 1 IPv6 Assignment: Autoconf
*c xConfiguration Network 1 IPv6 DHCPOptions: On
*c xConfiguration Network 1 QoS Mode: Diffserv
*c xConfiguration Network 1 QoS Diffserv Audio: 32
*c xConfiguration Network 1 QoS Diffserv Data: 32
*c xConfiguration Network 1 QoS Diffserv Signalling: 26
*c xConfiguration Network 1 QoS Diffserv Video: 32
*c xConfiguration Network 1 DNS Server 1 Address: "172.16.13.105"
*c xConfiguration Network 1 DNS Server 2 Address: "172.16.81.9"
*c xConfiguration Network 1 DNS Server 3 Address: ""
*c xConfiguration Network 1 DNS Domain Name: "hbfuller.com"
*c xConfiguration Network 1 IEEE8021X Mode: Off
*c xConfiguration Network 1 IEEE8021X TlsVerify: Off
*c xConfiguration Network 1 IEEE8021X UseClientCertificate: Off
*c xConfiguration Network 1 IEEE8021X AnonymousIdentity: ""
*c xConfiguration Network 1 IEEE8021X Identity: ""
*c xConfiguration Network 1 IEEE8021X Password: ""
*c xConfiguration Network 1 IEEE8021X Eap Md5: On
*c xConfiguration Network 1 IEEE8021X Eap Ttls: On
*c xConfiguration Network 1 IEEE8021X Eap Tls: On
*c xConfiguration Network 1 IEEE8021X Eap Peap: On
*c xConfiguration Network 1 MTU: 1500
*c xConfiguration Network 1 TrafficControl Mode: On
*c xConfiguration Network 1 RemoteAccess Allow: ""
*c xConfiguration Network 1 IPv4 SubnetMask: ""
*c xConfiguration Network 1 IPv4 Gateway: ""
*c xConfiguration Network 1 IPv4 Address: ""
*c xConfiguration NetworkServices XMLAPI Mode: On
*c xConfiguration NetworkServices Telnet Mode: On
*c xConfiguration NetworkServices SSH AllowPublicKey: On
*c xConfiguration NetworkServices HTTP Mode: On
*c xConfiguration NetworkServices HTTPS Mode: On
*c xConfiguration NetworkServices HTTPS VerifyServerCertificate: Off
*c xConfiguration NetworkServices HTTPS VerifyClientCertificate: Off
*c xConfiguration NetworkServices HTTPS OCSP URL: ""
*c xConfiguration NetworkServices HTTPS OCSP Mode: Off
*c xConfiguration NetworkServices SNMP Mode: ReadOnly
*c xConfiguration NetworkServices SNMP CommunityName: "public"
*c xConfiguration NetworkServices SNMP SystemContact: ""
*c xConfiguration NetworkServices SNMP SystemLocation: ""
*c xConfiguration NetworkServices SNMP Host 1 Address: ""
*c xConfiguration NetworkServices SNMP Host 2 Address: ""
*c xConfiguration NetworkServices SNMP Host 3 Address: ""
*c xConfiguration NetworkServices H323 Mode: Off
*c xConfiguration NetworkServices SIP Mode: On
*c xConfiguration NetworkServices NTP Mode: Auto
*c xConfiguration NetworkServices NTP Address: "172.16.9.50"
*c xConfiguration NetworkServices MultiWay Address: ""
*c xConfiguration NetworkServices MultiWay Protocol: Auto
*c xConfiguration Phonebook Server 1 ID: "default"
*c xConfiguration Phonebook Server 1 Type: CUCM
*c xConfiguration Phonebook Server 1 URL: "https://10.16.8.180:8443/cucm-uds/users"
*c xConfiguration Provisioning Mode: Off
*c xConfiguration Provisioning LoginName: ""
*c xConfiguration Provisioning Password: ""
*c xConfiguration Provisioning HttpMethod: POST
*c xConfiguration Provisioning ExternalManager Address: ""
*c xConfiguration Provisioning ExternalManager Protocol: HTTP
*c xConfiguration Provisioning ExternalManager Path: ""
*c xConfiguration Provisioning ExternalManager Domain: ""
*c xConfiguration Provisioning Connectivity: Auto
*c xConfiguration RTP Ports Range Start: 16384
*c xConfiguration RTP Ports Range Stop: 32766
*c xConfiguration Security Audit Server Address: ""
*c xConfiguration Security Audit Server Port: 514
*c xConfiguration Security Audit OnError Action: Ignore
*c xConfiguration Security Audit Logging Mode: Off
*c xConfiguration Security Session ShowLastLogon: Off
*c xConfiguration Security Session InactivityTimeout: 0
*c xConfiguration SerialPort Mode: On
*c xConfiguration SerialPort BaudRate: 38400
*c xConfiguration SerialPort LoginRequired: On
*c xConfiguration SIP Profile 1 URI: "7590"
*c xConfiguration SIP Profile 1 DisplayName: ""
*c xConfiguration SIP Profile 1 DefaultTransport: TCP
*c xConfiguration SIP Profile 1 TlsVerify: Off
*c xConfiguration SIP Profile 1 Type: Cisco
*c xConfiguration SIP Profile 1 Outbound: Off
*c xConfiguration SIP Profile 1 Proxy 1 Discovery: Manual
*c xConfiguration SIP Profile 1 Proxy 1 Address: "10.16.8.180"
*c xConfiguration SIP Profile 1 Proxy 2 Discovery: Manual
*c xConfiguration SIP Profile 1 Proxy 2 Address: ""
*c xConfiguration SIP Profile 1 Proxy 3 Discovery: Manual
*c xConfiguration SIP Profile 1 Proxy 3 Address: ""
*c xConfiguration SIP Profile 1 Proxy 4 Discovery: Manual
*c xConfiguration SIP Profile 1 Proxy 4 Address: ""
*c xConfiguration SIP Profile 1 Authentication 1 LoginName: ""
*c xConfiguration SIP Profile 1 Authentication 1 Password: ""
*c xConfiguration Standby Control: On
*c xConfiguration Standby Delay: 10
*c xConfiguration Standby WakeupAction: RestoreCameraPosition
*c xConfiguration Standby BootAction: DefaultCameraPosition
*c xConfiguration Standby StandbyAction: PrivacyPosition
*c xConfiguration SystemUnit Type: Shared
*c xConfiguration SystemUnit Name: ""
*c xConfiguration SystemUnit MenuLanguage: English
*c xConfiguration SystemUnit ContactInfo Type: Auto
*c xConfiguration SystemUnit CallLogging Mode: On
*c xConfiguration SystemUnit IrSensor: Auto
*c xConfiguration Time Zone: GMT-06:00 (Central America)
*c xConfiguration Time TimeFormat: 24H
*c xConfiguration Time DateFormat: DD_MM_YY
*c xConfiguration UserInterface TouchPanel DefaultPanel: ContactList
*c xConfiguration Video AllowWebSnapshots: Off
*c xConfiguration Video SelfviewPosition: LowerRight
*c xConfiguration Video Selfview: Off
*c xConfiguration Video Wallpaper: Waves
*c xConfiguration Video MainVideoSource: 2
*c xConfiguration Video DefaultPresentationSource: 2
*c xConfiguration Video Layout Scaling: On
*c xConfiguration Video Layout ScaleToFrame: MaintainAspectRatio
*c xConfiguration Video Layout ScaleToFrameThreshold: 5
*c xConfiguration Video Layout LocalLayoutFamily: Auto
*c xConfiguration Video Layout RemoteLayoutFamily: Auto
*c xConfiguration Video Monitors: Single
*c xConfiguration Video OSD Mode: On
*c xConfiguration Video OSD AutoSelectPresentationSource: Off
*c xConfiguration Video OSD TodaysBookings: Off
*c xConfiguration Video OSD MyContactsExpanded: Off
*c xConfiguration Video OSD Output: 1
*c xConfiguration Video OSD InputMethod InputLanguage: Latin
*c xConfiguration Video OSD InputMethod Cyrillic: Off
*c xConfiguration Video OSD LoginRequired: Off
*c xConfiguration Video Input Source 1 Name: "Camera"
*c xConfiguration Video Input Source 1 Connector: HDMI
*c xConfiguration Video Input Source 1 Type: camera
*c xConfiguration Video Input Source 1 CameraControl Mode: On
*c xConfiguration Video Input Source 1 CameraControl CameraId: 1
*c xConfiguration Video Input Source 1 Quality: Motion
*c xConfiguration Video Input Source 1 OptimalDefinition Profile: Normal
*c xConfiguration Video Input Source 1 OptimalDefinition Threshold60fps: 1280_720
*c xConfiguration Video Input Source 2 Name: "PC"
*c xConfiguration Video Input Source 2 Connector: DVI
*c xConfiguration Video Input Source 2 Type: PC
*c xConfiguration Video Input Source 2 CameraControl Mode: Off
*c xConfiguration Video Input Source 2 CameraControl CameraId: 1
*c xConfiguration Video Input Source 2 Quality: Sharpness
*c xConfiguration Video Input Source 2 OptimalDefinition Profile: Normal
*c xConfiguration Video Input Source 2 OptimalDefinition Threshold60fps: 1280_720
*c xConfiguration Video Input DVI 2 Type: AutoDetect
*c xConfiguration Video Output HDMI 1 Resolution: Auto
*c xConfiguration Video Output HDMI 1 OverscanLevel: None
*c xConfiguration Video Output HDMI 1 CEC Mode: Off
*c xConfiguration Video Output HDMI 1 MonitorRole: First
*c xConfiguration Video Output HDMI 2 Resolution: Auto
*c xConfiguration Video Output HDMI 2 OverscanLevel: None
*c xConfiguration Video Output HDMI 2 CEC Mode: Off
*c xConfiguration Video Output HDMI 2 MonitorRole: Second
** end
OK
Once both of you started to mention SSH I just enabled it and tried again, it worked this time! I would never think that it only pairs if SSH is enabled, so only with secure conection .
Thanks for your help!
Hi David.
The touch needs a secure connection.
The issue that you have been experiencing is normal when you
1. Disable ssh.
2. Use the non-encrypted TC software
I am glad you found the solution
//Marius
