C40 Dual Display with two local presentations (Local Only)
akarimian
We have a C40 unit with dual display option. We have a DVI input and an HDMI input setup to connect to two laptops. Is it possible to present both inputs at the same time? (DVI laptop to Left screen and HDMI laptop to Right screen) We are only able to select one presentation source from the touchscreen.
Thanks for your assistance.
rasimyigit
Yes. The first main source should set not the camera but laptop 1 or PC 1 and second source ( presentation) should set laptop2 / PC .
You can set this on the admin menu about http of the codec or about cli
