Cable Extension for SX20 with Precision HD 1080p 4x S2 Camera
Tomas Kriz
does anybody knows, if there is any possibility, how to extend original SX20 camera cabel for connection with 1080p4xS2 Camera? There is special HDMI+control square connector on both sides and I need to extend this cable. HDMI should work stand alone, but how to extend the second cable for camera control? I suppose, that is non-standard plug, so there is no possibilities how to produce own non-original cable...
Or, I maybe wrong??:)
Thanks for answer...
Tomas
leetoone22
So it looks like you can use 2 of the CAB-HDMI-PHD12XS cables. Use one for the camera and one for the codec end. They are 3m long, but you will either need an extender for the HDMI (and a barrel for the cat5) between them to connect, or an HDMI barrel if you can find one.
Lee, TPI Utah
And you would also have to power camera locally.
conmy
Hi all, I just wanted to share the information we have created for our partners after testing the Y-Cable.
You can check it out here: http://www.visitec.com/images/docs/Extending_PHD_4xS2_Camera.pdf
Chris Conmy Technical Support – Implementation – Sales Engineering Visitec Marketing Associates, Inc
