08-01-2005 07:14 PM - edited 03-17-2019 08:29 PM
Phone_A---PSTN---FXO-Router_A----IP NETWORK-----Router_B-FXS---Phone_B
Now I use Phone A to call phone B,making by PLAR.If there is nobody beside phone B,I hook off phone A,but Phone B continue to ring,how should i do?
thx indeed!
08-02-2005 08:29 AM
You are very likely running into an FXO disconnect problem. Take a look at the following URL:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml
Other URLs that might be helpful are:
http://www.cisco.com/en/US/products/sw/iosswrel/ps5013/products_feature_guide09186a0080080e48.html
http://www.cisco.com/en/US/products/sw/iosswrel/ps1834/products_feature_guide09186a00801601ac.html
08-22-2005 02:10 PM
You can have two issues involved.
FXO Supervision is implemented with different aproach either as an IOS feature or Battery reversal.
I prefer to use VIC-2FXO-M1 (USA) which incorporates battery reversal, just make shure you have it enabled on your voice-port.
Also check for a newer 12.3(4)T for your gateway so and try some or all of this commnand at your FXO ports too.
supervisory disconnect dualtone pre-connect
supervisory answer dualtone sensitivity high
battery-reversal answer
