Can 2 SX80's share 1 camera (P60)?
lmsjeremy
I am trying to set up a combinable space utilizing an SX80 and a Precision 60 in each room.  When the room is combined, I want the main codec to use the other camera as camera 2.  Is it possible?
I have both cameras on a switch linked to port 2 of each SX80.  Only 1 SX80 at a time seems to be able to see the cameras.
Any help would be much appreciated.
Martin Koch
This does not sound like a supported environment.
You might be able to do some tricks with an external control panel, being able to
unpair and pair the cameras and do some reconfiguration on your switches + some hdmi
switch, or use multisite to add the other camera to the call. but I am not sure if I would go these ways.
For me all of that sounds like issues with the usability at the end. And usability issues = frustrated users.
Maybe just add an additional camera with a proper view to the whole room connected to the main codec might be a way to go or just keep both systems completely separated.
But let us know what you did at the end and how happy you and your users were.
Wayne DeNardi
If you do not need control of the 2nd camera, you can connect the HDMI output of the camera to each of the SX80s with an HDMI splitter/DA (something like this: http://www.extron.com/product/product.aspx?id=hdmidaseries).  It effectively then just becomes a dumb camera from the device that doesn't have the control but can be fully controlled from the other.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
