Can not log in web access SX20 after reset factory
maitanlinhvn
hi all
i have a problem when i reset factory SX20. i finished to turn off SX20, then hold the power button for 10 seconds until it starts  blinking. Then press the power button twice. i don't know it have already been reset factory status yet.
But after that, i can not log in by web access. i can ping to SX20. but i can not log on Web or Telnet and i don't know what user admin and password are.
can you help me for that?
Please help me to check it.
Thanks all
Patrick Sparkman
If you're able to browse to the login screen using a web browser, the default username is "admin" with no password.  Telnet is disabled by default.
Patrick Sparkman
Laurent Ponchon
What address should use it after a reset?
Unable to get an IP address
By default, the endpoint will obtain an IP address from DHCP.  Connect the codec to a monitor so you can access the OSD and locate the IP it's using.
