can we change the CMS interface a and admin IP address after deployement??
Prasad Paradkar
Hi All,
We have a non live infra and its a single combined server, want to know if we change its admin and interface a ip address, what else will get impacted on CMS side.
Patrick Sparkman
Any component that is referencing the old IP address will stop working until you change it.
as its a single combines deployement I dont know it will effect anything --
1> there is no DB reploication so no need to change IP there.
2> no SIP edge to change the IP
If I am missing naything plz let me know
Prasad Paradkar
Prasad,
This should not affect anything. The only thing you would need to update, possibly, is the address for the callbridge server in the web GUI, unless you have it as "localhost" already.
Thank you,
Justin Ferello
Technical Support Specialist, ScanSource KBZ
You would need to update DNS obviously, this applies for any options that are using FQDN, such as "Guest account client URI" and "Web Bridge URI" under Configuration > General in the web interface.
