change wallpaper via API for all device
orcunulutas
we have more then 300 devices and i need to change wallpaper on all device.
i know following command ;
xConfiguration Video Wallpaper: custom
however, i need upload wallpaper to all device. i guess very long time upload file via web interface.
i tried root login enable however, i give following error message ;
Root access no longer available on TC release builds. Please use the remotesupport account for uses which previously required root access.
so, how can i push wallpaper to all device via API or anything ?
seems not login to device via scp and sftp because root login disabled with new versions of TC firmware.
20 Replies 20
Magnus Ohm
Here is a simple python script for uploading wallpapers to multiple codecs. Its not exactly async as it would indicate, but it works.
import asyncio
import aiohttp
import aiofiles
async def send(session, img, url):
    data = aiohttp.FormData()
    async with aiofiles.open(img, mode='rb') as f:
        data.add_field('file', f, filename=img, content_type='image/png')
        async with session.post(url, data=data) as response:
            print(response.status)
async def main(devices):
    for k,v in devices.items():
        (user,password) = v.split(':')
        url = 'https://{}/api/wallpapers'.format(k)
        auth = aiohttp.BasicAuth(login=user, password=password)
        async with aiohttp.ClientSession(auth=auth, connector=aiohttp.TCPConnector(ssl=False)) as session:
            await send(session, 'wallpaper_test.png', url)
devices = {'10.10.10.1':'admin:',
           '10.10.10.2':'admin:'}
asyncio.run(main(devices))
/Magnus
Thank you Magnus
Hi Magnus,
 I notice that there is also a URL to POST a backup
https://codecipaddress/api/backup
Could your python code be amended to post a backup file to a number of codecs? If so is the file format a zip? Many Thanks
Sergio Quezada
I have been using CE-Deploy. I have posted the link to the software below.
https://github.com/voipnorm/CE-Deploy/releases/tag/v7.3.2
Thanks for you reply squezada. CE-deploy is excellent. Bear in mind it only works on Windows 10/Mac , and you need an internet connection.
Sergio Quezada
The tool I use now is CE-Deploy  works great.
Sergio Quezada
