Cisco C60 custom wallpaper looks stretched out
Sridhar Bheeman
cisco C60 device type: Profile 52” Dual
Resolution: Dual 52” Full HD LCD, 16:9, 1080 x 1920 resolution.
custom Wallpaper resolution: 1080 x 1920
Layout settings have been set to stretch to fit.
Yet the wallpaper looks stretched out, any suggestions to get this issue fixed ?
I think you have your horizontal and vertical dimensions around the wrong way.  Your image should be:1920 wide x 1080 high
Also check the Video Output Resolution setting in the configuration to check that this also matches and isn't trying to force the display to a lower resolution.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Wayne
