12-04-2020 02:03 AM - edited 12-04-2020 02:22 AM
Dears
I have problem with disconnectOthersAllowed callLegProfile setting
WebRTC doesn't inherit the "Disconnectothersallowed" parameter set in the call leg profile
How can i limit participants to drop other participants when they login via WebRTC or CMA?????????
I use Cisco Meeting Server 2.9 and 2.8
12-28-2020 08:56 PM
Did you assign calllegprofile at cospace level or system level? make sure it is at cospace level.
Active control should be enabled and negotiated for SIP endpoints
Disconnectothersallowed does not work for CMA but works for WebRTC
12-28-2020 09:21 PM
Hello
thanks for your reply
I assigned at both of them (system level and cosapce level) but it made no difference
I checked CMA and Webrtc but for both of them Disconnectothersallowed did not work
I also have other problems , In a meeting when i changed Layout or Pane placement via CMM no change happens for Webrtc and CMA users but take effect on Meeting Room Device like Tandberg Codec
As my understanding Logged in user via Webrtc has lot of limitation!!!!! Is it correct?
12-31-2020 01:52 PM
PLZ let me know if these features not supported on CMS because I have a lot of project that I suspend them to resolve these problem first
12-31-2020 05:39 PM
Hello
Disconnectothersallowed should work with SIP and WebRTC participants. SIP Participants should be enabled and negotiated with activecontrol. Did you try to use this between 2 webRTC participants, are they able to disconnect each other.
Changing layout via CMM will change layout of SIP Participants, WebRTC participants can change layouts them self from on-screen.
01-01-2021 02:28 AM
As I Know WebRTC participants use SIP protocol and as my understanding sip and webrtc are the same if this issue is not correct plz let me know anyway when two webrtc participants LOGIN to conference they don't inheritance
"disconnectOthersAllowed=false" anymore and they can disconnect each other in other hands if Webrtc participants JOIN MEETING everything is reversed and if "disconnectOthersAllowed" parameter set to true none of participant can disconnect each other??????!!!!!!!!
About layout ok webrtc participants can change their layout but the very important thing is to change Pane Placement for WebRTC participants from CMM or API !!!!! How can i do this ????
Please send me the sample config to make sure that these issues are possible or if these are Cisco bugs please let me know
01-05-2021 08:44 PM
Dear Sateesh
Do you have any idea for these issues that I mentioned in previous post????
02-12-2021 10:10 PM
Hi friends
Anybody has any Idea?????
