Cisco codec control simulator
nickoblong
We are integrating our product with various Cisco VTC codecs using each of the codecs RS232 serial interface. Does Cisco have a simulator or test bench that our solution can be tested against? I would like to validate that our control will work on all C and SX series codecs.
Thanks.
Patrick Sparkman
As long as you use the API guides for each product you plan on integrating with, you should be fine.  Other than testing with an actual endpoint, not sure what else you can use.
C Series API Reference Guides
SX Series API Reference Guides
