Cisco Codec Macros
Dean O'Meara
Good morning,
Would anyone know how many Macros can be safely run or the limit on a Cisco Codec? Let's take a Room Kit Mini for example.
I have spent hours trying to find this information online but unfortunately not found anything so any advice would be greatly appreciated.
I don't believe there is a set "number of macros" that can be configured.
Given that any macro can be of varying capabilities and length, the amount of memory and storage capacity would have more affect on what can be present than any specific "number" of macros.
If you start having to have too many large macros on your device, then you're possibly better off using an external control system that is more flexible than trying to do everything on the codec.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
clarkhind
Hi Dean,
I found this:
If you can do the actions in the xAPI you can in most scenarios automate it using the macro
framework. You can create up to 10 individual macro scripts on a supported system.
From here:
https://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/software/ce9/release-notes/ce-software-release-notes-ce9.pdf
Hope this helps.
Clark
