Cisco Codec Pro Question
Terry Bynum
Basically, the integer range of settings for a CODECPro for audio input level is 0..70 with a default level of 58.  Is there a direct correlation to actual dB level with the integers?  In other words, does 0 correspond to a gain of 0 dBu and 70 correspond to a gain of 70dBu?
0 Replies 0
