Cisco Jabber Video 4.4 - how to disable "remember me" check box.
oizciloiz
Hi All
=Situation=
We are authenticating the Jabber Video users againts the MS Active Directory in TMS.
If in Jabber Video the "remember me" check box is ticket and a user changes the password in MS Active Directory, after few Jabber Video login attempts the account will be locked in MS Active Directory.
=Question=
Is this a known behavior ?
A) What would you suggest as remedy
B) Is there possibility to disable the "remember me" check box.
C) To save system resources - are there options as well to disable the check boxes in Sign-in Settings "Start Jabber Video wehn I log on to my computer" & "Sign in automatically".
Unfortunately this will be a show stopper, If I am not able to fix this issue.
I would appreciate any kind of feedback.
Thanks in Advanced
Alessandro
Magnus Ohm
https://supportforums.cisco.com/thread/2174346?tstart=0
Maybe this thread will help you.
/Magnus
