Cisco Room kit plus
Tan28
Hi, I currently setting up cisco room kit plus with quad camera and 2 P60 camera. Now the set up is quad camera hdmi is direct connected to codec hdmi 1, the 2 P60 camera hdmi is connected to hdmi switcher then out to codec hdmi 2. I need the codec hdmi 3 to do a send content to far end. But the problem is I can’t control all the 3 camera. Although I already connected all 3 camera lan and codec camera control port lan to the switch. Can someone advise how to solve it? I had done all configuration in the web browser. The attached file is the picture I took from touch 10.
Wayne DeNardi
The camera LAN port should be connected to your normal LAN switch.   You should then connect the Camera LAN port on the codec to a separate small switch to which all your cameras connect to (unless your main LAN switch has a separate VLAN configured for the camera LAN connections from each of the devices).
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
