Cisco Touch 10; Configure Call
Kaliafeh Wright
Level 4
Level 4
Hello is there a way to Change the layout inside of call on the Touch 10?
We would like "Directory" to show before "Recents".
Is there a way to make this happen?
Thanks in advance
P.S. - I did take a look at the "In Room Control", from what I saw I was not able to configure the main layout unless I wanted to add the in-room controls to the existing layout.
Patrick Sparkman
It’s not possible to change the layout of the buttons and options within the Touch 10.
Patrick Sparkman
Thank you.
We are going to turn off history in the config. and that will leave "Favorites" and "Directory" under the "Call" function.
