CLUSTERING CMS A/V NOT PASSING BETWEEN SERVERS
Chet Cronin
Level 4
Level 4
I am running CMS 2.9.2 clustered.
Problem
1. All Desktop and Conference Room systems connect to cb1
2. Chrome - CMA calls most of the time will connect to cb3
They are all dialing into the same CONF ID.
Problem is A/V doesn't pass between cb1 or cb3 and vice versa
I will disconnect the CMA and than dial back in and it will connect to cb1 ?
Any Idease why the A/V doesn't pass between clustered servers on the same CONF ID?
Any Ideas how to force calls using web to go to cb1 first and then next participant roles to cb2 when cb1 is at capacity ?
Thanks.
Chet Cronin
vikdutta
Make sure u have Outbound rules right. if u have 6 callbridges in cluster ull need 6 OB rules
However, when configuring the dial plan to route calls between Call Bridges
(when ‘Peer link SIP domain’ field is left empty), you need to use the Call Bridge’s IP address in
both ‘domain’ and ‘sip proxy address’ fields of the outbound dial plan
//V.
6 Replies 6
Sergey 1907
Maybe this will help you
If you have a cluster, all connections must be through one URL, is that so with you?
Yes we are using one URL to connect but most connect to cb3 and sometimes cb1.
No A/V pass between the cb3 and cb1 ?
Chet Cronin
Does anyone have an example config for load balancing six cb's make cb1, Priority 1 following cb2, cb3, cb4 etc. ??
Thank you.
Chet Cronin
May be it ?
vikdutta
//V.
Thank you that worked.
Chet Cronin
