CMS LDAP Automatic Sync
Nishad Ismail
CMS 2.6.1 simple deployment
any option to configure LDAP Automatic Sync ,I don't find option for LDAP Automatic Sync
Currently we are facing problem when users changed the password and  importing new users from LDAP .
LDAP users not allowed to login until i do manual Sync
Anurag Srivastava1
Yes still there is no automatic sync from ldap servers
probably you can open a feature request with cisco.
but changing password should not be an issue to login users as it was already synced and for authentication CMS will contact LDAP server only.
If that is not happening probably you need to take details traces and check.
yes but importing new users will only happen when you perform sync.
Please rate if it is helpful...
Please rate if it is helpful and mark as accepted solution if applicable....
