I have CMS1, CMS2, DB Cluster, I'm planing to add 2 CMS servers that both will be running recording and streaming
roles, what is correct commands to configure the XMPP on the server and the 2 XMPP clients
Note that callbridge is not running on the 2 new server do I still need to use command:
cms1>xmpp callbridge add CMS-ST-REC1
cms1>xmpp callbridge add CMS-ST-REC2
