05-17-2005 05:32 AM - edited 03-17-2019 08:26 PM
1. Cisco 2821 with VIC2-4FXO connect to NEC PBX via Ext.
When the call as below is ok
The calls were make from the voip leg toward the pots leg(PBX).
PBX --------- 2821 ------------voip
<---------- call direction
But as below isn't work !
call direction ----->
2. Anybody had the same issue ?
3. I use other PBX KX-TA308, it's work very good.
05-19-2005 11:22 AM
I have the same issue also third party FXO, I think FXO not recognize the RingOute call fron PBX. I'am at working on ...
ehs(not-type-this)@ehs2000.com
Mauro
05-19-2005 06:29 PM
Anyway, how you fixed this issue ?
