06-19-2014 06:51 AM - edited 03-18-2019 03:05 AM
Is it possible, using TMS, or other method, to copy configurations from one system to another? I have 10 new SX20s to deploy that I would like to be set up exactly the same (different H323 info, of course). Can Persistent settings be used to copy a config to create a template?
Darren
06-19-2014 07:03 AM
Please remember to mark helpful responses and to set your question as answered if appropriate.
06-19-2014 07:39 AM
Yes, this is how I do things too.
I asked this very question several years back and I can't quite believe there is no simple way to do this in TMS (as far as I know) which is where you would have thought that such an operation would take place.
Cheers
Chris
06-19-2014 09:42 AM
Have you considered using configuration templates? It would require you to setup one template yes, but once done, it's just a matter of pushing it out via TMS. Good thing is that you can edit or update the template and push it out over and over to configure endpoints as you need. Quicker than logging into CLI of each endpoint.
06-19-2014 10:02 AM
Patrick, you're right, I could build a template. I was just asking why there isn't an easier way. You would think by now I could build a template from an existing system.
06-19-2014 10:06 AM
That would be nice, like the ability to take the configuration xml file from the codec and upload it to TMS to generate a template from it.
06-19-2014 10:14 AM
I asked that question a few years ago as well. Looks like no one is listening.......
