CTS video through Cube to 9971 doesn't work well
gilbert spoor
I am running a Lab with two CUCM8.6.2 environments and a router acting as CUBE in between.
In one environment I have a video SIP phone (Cisco E20) and a cts-1100 running software 1.9.
in the other environment I have an E20 and a Cisco 9971 video enabled phone.
a cisco 2921 router is configured for the CUBE functionality.
I can call between the two environments without any problem using the E20's audio and video gets relayed by the cube.
But when calling between the CTS-1100 and the E20 or the 9971 in the other environmkent doesn't work well, the E20 doesn't receive video or audio and remains in an answering state, while the CTS receives audio and video from the e20 through the cube (so one way media)
when the CTS calls the E20 that is registered to the same callmanager audio and video work fine.
does anyone know what I'm doing wrong?
Below the config of the router:
version 15.0
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
ip source-route
ip cef
vlan ifdescr detail
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
rtp-ssrc multiplex
address-hiding
allow-connections sip to sip
redirect ip2ip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface Loopback0
bind media source-interface Loopback0
session transport tcp
rel1xx disable
header-passing sip-sip
midcall-signaling passthru
g729 annexb-all
pass-thru content sdp
voice class codec 1
codec preference 1 aacld
codec preference 2 g711alaw
codec preference 3 g711ulaw
codec preference 4 g722-64
codec preference 5 g728
hw-module pvdm 0/0
interface Loopback0
ip address 10.0.0.1 255.255.255.255
interface GigabitEthernet0/0
ip address 192.168.222.10 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 10.1.1.254 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/2
ip address 10.2.2.254 255.255.255.0
duplex auto
speed auto
ip forward-protocol nd
no ip http server
ip http secure-server
ip route 192.168.255.0 255.255.255.0 192.168.222.254
control-plane
codec profile 1 aacld
codec profile 2 h264
codec profile 3 h263+
codec profile 4 h263
dial-peer voice 1 voip
description cucm1
destination-pattern 1...
rtp payload-type cisco-codec-video-h264 112
session protocol sipv2
session target ipv4:10.1.1.1
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 2 voip
description cucm2
destination-pattern 3...
session target ipv4:10.2.2.1
voice-class codec 1
dtmf-relay rtp-nte
sip-ua
no remote-party-id
retry invite 2
gatekeeper
shutdown
15 Replies 15
Yep - pretty sure that CTS units use 10.x.x.x for the connection to the presentation codec and camera etc, unless you are using 10.x.x.x on your LAN in which case it uses something else (192.x.x.x?)
Good find, glad you got it sorted out... I never would have thought of that!
