CUCM Integration with Lync
Abdu
I have one Lync server, can I register lync client on cucm like jabber?, also can i forward call from lync directly to voice GW
abdel-moniem
Level 5
Level 5
Hello Abdul-Majeed,
I don't believe so, Microsoft Lync registeration should be on MS Lync Server and integration can be done between Cisco and MS Lync can be done in several ways depends on what type of integraton you need. CUCILync can be used for this integration as a softphone or desktop phone call control, also SIP integration with Lync Front End..
With Lync 2013/Skype for Business, flow around mode allow media termination to the Cisco Voice gateway.
Actually, i have Lync 2013/Skype for business, and I need anyone have skype for business can dial any IP Phone on CUCM from his Skype for business, Can we do it?
Hello Abdul-Majid,
There is a Good guide in performing this integration between both,
http://www.cisco.com/c/dam/en/us/solutions/collateral/enterprise/interoperability-portal/uc-manager.pdf
Tell me if this helps,
Abdel-moniem REZK
rate if it helps
