05-22-2016 04:22 PM - edited 03-18-2019 05:58 AM
Is anybody able to tell me the CUCM version requirement for Multistream to work?
I'm hoping to get it deployed on a CUCM 10.5.2 cluster, but I'm not sure if it requires version 11 I haven't had much luck finding an answer....
Solved! Go to Solution.
05-22-2016 04:46 PM
CUCM 10.5(2) is required to support multistream video. Refer to the TelePresence Server 4.1 Release Notes to see the other requirements.
05-22-2016 04:46 PM
05-22-2016 05:09 PM
Thanks Patrick, I was looking in CE8 release notes instead.
