01-13-2012 12:19 PM - edited 03-17-2019 10:43 PM
Does anybody know where I can find information on the pros and cons of registering video endpoints to CUCM and VCS?
Mike
Solved! Go to Solution.
01-13-2012 03:19 PM
have a look at this ask the expert session
https://supportforums.cisco.com/message/3534072#3534072
advantages :
1. you can leverage BFCP support on the endpoints and do presentation share with other UCM video capable endpoints
2. if you just have Unified communications in your enterprise you can leverage these gears for point to point video call with other UCM video capable endpoints , like Ex90 --- to ---- CTS with no xcoder in between
3. endpoints support TIP
4. you can join adhoc video conference from these phones
5. High resolution video
6. you can leverage same voicemail system that is being used for UCM phones
Register endpoints to VCS when these are required
hope this help
if helpful rate
01-13-2012 03:19 PM
advantages :
hope this help
if helpful rate
01-16-2012 02:03 PM
Awesome, just what I was looking for. Thanks.
