dial peer config question
anitachoi3
My proivider support E164 with "+" sign. e.g. provider sends the call to us is
or (provider receives the call from us is)
+8862660....
how to config the dial peer of cicso router 5400?
dial-peer voice 88601 pots
destination-pattern ?????
or
dial-peer voice 88602 voip
destination-pattern ??????
rdgs
paolo bevilacqua
just ignore the plus sign. Use destination-pattern with the digits only.
A:
if the provider sends me the traffic
+8861111111
my dial peer
destination-pattern +886T
B:
if I send the traffic to provider
my dial peer
It doesn't work, any idea?
rgds
Hi, for incoming please use
incoming called-number 886
for outgoing use destination-pattern.
Avoid T is possible at all, use dots in place of digits that can be varying.
