Different between CTS-PWR-AIR-INJ5+ and CTS-POE-INJ
Ka Fai Tse
The "CTS-PWR-AIR-INJ5+" can be ordered when we purchase CTS-CTRL-DVX-10 from Cisco
and the "CTS-POE-INJ" can be ordered when we purchase the CTS-SX20-PHD12X-K9 from Cisco
both of them are used by the Touch 10 (CTS-CTRL-DVX-10) for the SX20
what is the difference between them? are they actually the same thing?
adawa
Level 3
Level 3
Hello, Ka Fai Tse.
Packaging and extra cables is may only be the difference between the two, I recommend purchasing the advised part number on each device.
Let me know if you have additional concerns or e-mail (adawa@cisco.com) me directly. Kind regards.
Hi adawa i'm ordering CTS-SX20-PHD12X-K9 with Touch 10 and power injector for it CTS-POE-INJ. I have clear that it includes ethernet cable but im not sure if it includes a power cable or i have to order it as spare.
I didnt find anything about it.
Do you know if it include it?
Thanks in Advance!
Adrian,
You've probably already purchased the Injector by now.  But NO Cisco won't include the flat Ethernet or any Ethernet cable for that fact with the power injector.
You also need to specify the Power Cable that plugs into the Injector as well.
KT...
