12-05-2002 07:30 AM - edited 03-17-2019 07:56 PM
I'm using cisco as5300 and channel bank for voip (terminate).
when voip call leg recieved to my gateway and used DS0 number 10 of 30 , the voice conversation is one way (don't have ReceiveBytes) but when used other DS0 channel,gateway normaly work!
Could you please advice me?
Please see below (show call active voice)
GENERIC:
SetupTime=61530034 ms
Index=1
PeerAddress=
PeerSubAddress=
PeerId=666
PeerIfIndex=38
LogicalIfIndex=0
ConnectTime=0
CallDuration=00:00:00
CallState=3
CallOrigin=2
ChargedUnits=0
InfoType=2
TransmitPackets=2172
TransmitBytes=86880
ReceivePackets=0 <----------------
ReceiveBytes=0 <---------------
Separate H245 Connection=FALSE
H245 Tunneling=FALSE
SessionProtocol=cisco
SessionTarget=
OnTimeRvPlayout=0
GapFillWithSilence=0 ms
GapFillWithPrediction=0 ms
GapFillWithInterpolation=0 ms
GapFillWithRedundancy=0 ms
HiWaterPlayoutDelay=70 ms
LoWaterPlayoutDelay=70 ms
ReceiveDelay=70 ms
LostPackets=0
EarlyPackets=0
LatePackets=0
VAD = disabled
CoderTypeRate=g729r8
CodecBytes=40
SignalingType=ext-signal
GENERIC:
Index=2
Thank you,
Mehrdad
12-08-2002 11:15 AM
Does this just happen on timeslot 10, do all other timeslots work OK?
If it is just timeslot 10, I would advise talking to the provider about this timeslot.
Othersiwse more info is needed such a IOS version and topology as well as a sh run and possibly a debug voip ccapi all of the failed call.
12-08-2002 11:28 PM
Thank you for your reply
also you know , i'm using as5300 and channel bank ,other timeslots work normality but timeslot 10 many times is work one way !
Cisco IOS is 12.2(5)
Best Regards,
Mehrdad
12-09-2002 04:15 PM
all time slots work good, all have voice configuration and all is same problem, the call is good, but in the first words loss to remote router.
IOS version is 12.2.11T in remote router and corporativo router is 12.2.12a
this is running config of corporativo.
wr t
Building configuration...
Busyout is not supported on this voice-port.
Current configuration : 9075 bytes
version 12.2
hostname Corporativo
logging buffered 100000 debugging
enable password caracol
memory-size iomem 30
voice-card 1
ip subnet-zero
ip cef
class-map match-all voip
--More-- match access-group 110
class-map match-all atli
class-map match-all mata
class-map match-all vela
class-map match-all texme
class-map match-all tehua
class-map match-all pluvo
class-map match-all hidro
class-map match-all huejo
policy-map tehuacan
class tehua
set ip precedence 5
bandwidth 35
--More-- class class-default
fair-queue
policy-map pluvosilla
class pluvo
set ip precedence 5
bandwidth 35
class class-default
fair-queue
policy-map hidrogas
class hidro
set ip precedence 5
bandwidth 35
class class-default
fair-queue
queue-limit 32
policy-map texmelucan
class texme
bandwidth 35
set ip precedence 5
class class-default
fair-queue
policy-map atlixco
class atli
--More-- set ip precedence 5
bandwidth 35
class class-default
fair-queue
policy-map velagas
class vela
bandwidth 35
queue-limit 96
set ip precedence 5
class class-default
fair-queue
queue-limit 32
policy-map llq
class voip
set ip precedence 5
police 35000 1500 1500 conform-action transmit exceed-action transmit violate-action transmit
bandwidth 35
class class-default
fair-queue
police 16000 1500 1500 conform-action transmit exceed-action set-prec-transmit 2 violate-action set-prec-transmit 0
policy-map matamoros
--More-- class mata
set ip precedence 5
bandwidth 35
class class-default
fair-queue
policy-map huejotzingo
class huejo
set ip precedence 5
bandwidth 35
class class-default
fair-queue
call rsvp-sync
controller E1 0/0
framing NO-CRC4
channel-group 2 timeslots 2
channel-group 4 timeslots 4
--More-- channel-group 10 timeslots 10
channel-group 11 timeslots 11
channel-group 13 timeslots 13
channel-group 14 timeslots 14
channel-group 15 timeslots 15
channel-group 16 timeslots 16
channel-group 17 timeslots 17
description E1 a Telmex
controller E1 1/0
framing NO-CRC4
line-termination 75-ohm
ds0-group 1 timeslots 1-15,17-24 type r2-digital r2-compelled
cas-custom 1
country telmex use-defaults
category 2
answer-signal group-b 1
interface Loopback1
description *** USED FOR VOIP ONLY ***
ip address 192.168.2.1 255.255.255.255
--More-- h323-gateway voip bind srcaddr 192.168.2.1
interface Multilink2
bandwidth 64
ip address 192.168.1.21 255.255.255.252
ip tcp header-compression iphc-format
no ip mroute-cache
max-reserved-bandwidth 80
service-policy output hidrogas
no cdp enable
ppp multilink
ppp multilink fragment-delay 10
ppp multilink interleave
multilink-group 2
ip rtp header-compression iphc-format
interface Multilink3
bandwidth 64
ip address 192.168.1.29 255.255.255.252
no ip mroute-cache
service-policy output velagas
--More-- no cdp enable
ppp multilink
multilink-group 3
interface Multilink4
bandwidth 64
ip address 192.168.1.25 255.255.255.252
no ip mroute-cache
service-policy output llq
no cdp enable
ppp multilink
multilink-group 4
interface Multilink5
bandwidth 64
--More-- ip address 192.168.1.5 255.255.255.252
no ip mroute-cache
service-policy output tehuacan
no cdp enable
ppp multilink
ppp multilink fragment-delay 20
multilink-group 5
interface Multilink7
bandwidth 64
ip address 192.168.1.9 255.255.255.252
no ip mroute-cache
service-policy output atlixco
no cdp enable
ppp multilink
--More-- multilink-group 7
interface Multilink8
bandwidth 64
ip address 192.168.1.17 255.255.255.252
no ip mroute-cache
service-policy output texmelucan
no cdp enable
ppp multilink
multilink-group 8
interface Multilink9
bandwidth 64
ip address 192.168.1.1 255.255.255.252
no ip mroute-cache
--More-- service-policy output huejotzingo
no cdp enable
ppp multilink
multilink-group 9
interface Multilink10
bandwidth 64
ip address 192.168.1.13 255.255.255.252
no ip mroute-cache
service-policy output matamoros
no cdp enable
ppp multilink
multilink-group 10
interface Multilink11
--More-- bandwidth 64
ip address 192.168.1.33 255.255.255.252
no ip mroute-cache
service-policy output pluvosilla
no cdp enable
ppp multilink
multilink-group 11
interface FastEthernet0/0
ip address 172.16.1.1 255.255.255.0
duplex auto
speed auto
no cdp enable
interface Serial0/0:2
description Enlace a Velagas
bandwidth 64
no ip address
--More-- encapsulation ppp
no fair-queue
no cdp enable
ppp multilink
multilink-group 3
interface Serial0/0:4
description Enlace a Pluvosilla
bandwidth 64
no ip address
encapsulation ppp
no fair-queue
no cdp enable
ppp multilink
multilink-group 11
interface Serial0/0:10
description Enlace a Hidrogas
bandwidth 64
no ip address
encapsulation ppp
no fair-queue
no cdp enable
--More-- ppp multilink
multilink-group 2
interface Serial0/0:11
description Enlace a Oriente
bandwidth 64
no ip address
encapsulation ppp
no fair-queue
no cdp enable
ppp multilink
multilink-group 4
interface Serial0/0:13
description Enlace a Huejotzingo
bandwidth 64
no ip address
encapsulation ppp
no fair-queue
no cdp enable
ppp multilink
multilink-group 9
--More-- interface Serial0/0:14
description Enlace Tehuacan
bandwidth 64
no ip address
encapsulation ppp
no fair-queue
no cdp enable
ppp multilink
multilink-group 5
interface Serial0/0:15
description enlace a Atlixco
bandwidth 64
no ip address
encapsulation ppp
no fair-queue
no cdp enable
ppp multilink
multilink-group 7
interface Serial0/0:16
description Enlace a Matamoros
bandwidth 64
--More-- no ip address
encapsulation ppp
no fair-queue
no cdp enable
ppp multilink
multilink-group 10
interface Serial0/0:17
description enlace a Texmelucan
bandwidth 64
no ip address
encapsulation ppp
no fair-queue
no cdp enable
ppp multilink
multilink-group 8
router eigrp 100
network 172.16.0.0
network 192.168.1.0
network 192.168.2.0
no auto-summary
--More-- no ip classless
ip route 0.0.0.0 0.0.0.0 172.16.1.2
no ip http server
access-list 100 permit udp any range 16384 32767 any range 16384 32767
access-list 110 permit udp any range 16384 32767 any range 16384 32767
access-list 110 permit tcp any eq 1720 any eq 1720
access-list 2201 permit tcp any any eq www
no cdp run
snmp-server packetsize 4096
snmp-server enable traps tty
voice-port 1/0:1
output attenuation 6
echo-cancel coverage 32
dial-peer cor custom
dial-peer voice 1310 voip
destination-pattern 10...
session target ipv4:192.168.2.2
--More-- ip precedence 5
dial-peer voice 1320 voip
destination-pattern 20...
session target ipv4:192.168.2.3
ip precedence 5
dial-peer voice 1330 voip
destination-pattern 30...
session target ipv4:192.168.2.4
ip precedence 5
dial-peer voice 1340 voip
destination-pattern 40
session target ipv4:192.168.2.7
ip precedence 5
dial-peer voice 1350 voip
destination-pattern 50
session target ipv4:192.168.2.5
ip precedence 5
dial-peer voice 1360 voip
--More-- destination-pattern 60
session target ipv4:192.168.2.8
ip precedence 5
dial-peer voice 1370 voip
destination-pattern 70
session target ipv4:192.168.2.9
ip precedence 5
dial-peer voice 1380 voip
destination-pattern 80
session target ipv4:192.168.2.10
ip precedence 5
dial-peer voice 1390 voip
destination-pattern 90
session target ipv4:192.168.2.11
ip precedence 5
dial-peer voice 13200 pots
destination-pattern 22...
direct-inward-dial
port 1/0:1
--More-- !
line con 0
line aux 0
line vty 0 4
password caracol
login
end
Corporativo#sh ver
IOS (tm) 3600 Software (C3640-IS-M), Version 12.2(12a), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Tue 24-Sep-02 00:30 by pwade
Image text-base: 0x60008930, data-base: 0x610F4000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Corporativo uptime is 4 days, 5 hours, 25 minutes
System returned to ROM by bus error at PC 0x60E69DDC, address 0xB0D0B59
System image file is "flash:c3640-is-mz.122-12a.bin"
cisco 3640 (R4700) processor (revision 0x00) with 46080K/19456K bytes of memory.
Processor board ID 27623437
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Primary Rate ISDN software, Version 1.1.
1 FastEthernet/IEEE 802.3 interface(s)
9 Serial network interface(s)
--More-- 2 Channelized E1/PRI port(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Corporativo#sh mem sum
Head Total(b) Used(b) Free(b) Lowest(b) Largest(b)
Processor 61D22620 16636384 8779016 7857368 7634108 7805788
I/O 2D00000 19922944 3277032 16645912 16633488 16642812
--More--
Corporativo#sh proce cpu
CPU utilization for five seconds: 1%/0%; one minute: 2%; five minutes: 1%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
1 0 1 0 0.00% 0.00% 0.00% 0 Chunk Manager
2 0 73034 0 0.00% 0.00% 0.00% 0 Load Meter
3 12 73 164 0.00% 0.00% 0.00% 0 PPP auth
4 215308 43219 4981 0.65% 0.08% 0.06% 0 Check heaps
5 0 1 0 0.00% 0.00% 0.00% 0 Chunk Manager
6 8 12 666 0.00% 0.00% 0.00% 0 Pool Manager
7 0 2 0 0.00% 0.00% 0.00% 0 Timers
8 2772 75 36960 0.00% 0.00% 0.00% 0 Serial Backgroun
9 336 72988 4 0.00% 0.00% 0.00% 0 ALARM_TRIGGER_SC
10 0 1 0 0.00% 0.00% 0.00% 0 OIR Handler
11 0 12173 0 0.00% 0.00% 0.00% 0 Environmental mo
12 11036 25670 429 0.00% 0.01% 0.00% 0 ARP Input
13 156 86185 1 0.00% 0.00% 0.00% 0 HC Counter Timer
14 0 19 0 0.00% 0.00% 0.00% 0 DDR Timers
15 0 2 0 0.00% 0.00% 0.00% 0 Dialer event
16 0 2 0 0.00% 0.00% 0.00% 0 Entity MIB API
17 0 1 0 0.00% 0.00% 0.00% 0 SERIAL A'detect
18 0 1 0 0.00% 0.00% 0.00% 0 Critical Bkgnd
19 2760 105020 26 0.00% 0.00% 0.00% 0 Net Background
20 4 238 16 0.00% 0.00% 0.00% 0 Logger
21 280 365050 0 0.00% 0.00% 0.00% 0 TTY Background
--More--
Corporativo#
