DX80 converting from Android to CE without CUCM
sipr_ttgp
I have a DX80 that I am trying to get converted from android to CE. I cannot upgrade through the web (TFTP Blocked) and cannot upgrade through CUCM. I have updated the software from 10-2-4-56 to 10-2-5-213 using a laptop with Cisco tftp installed. I found a sample .xml file that I rename to the serial of the DX80 and set the filename to the .sgn file needed. The problem that I am having is that when I use the same procedure to do the conversion it does not work. The file that I am using on the tftp server is 'cmterm-synergy-ce8_2_1_no_defauls.cop.sgn'. What am I missing?
15 Replies 15
H.323 is available in CE8.2.0 and later.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
