Edge 95 MXP Firmware Upgrade
thomas.burch
I have recently come into an operation using a legacy Tandberg Edge 95. The firmware on the unit, from what I can tell has never been updated. It is currently running F6.0. I have downloaded the F9.0.2 pkg but I am unfamiliar with this procedure. Can anyone assist or point me to an insturctional site on updating this unit?
15 Replies 15
Dear: There is some way to know exactly what the problem is (command, log). also I would like to indicate that I have several computers that are the same model and have the same firmware, in which the update does not work either, yielding the same error as before.
I would appreciate if you could give me some ideas to find the flaw.
thanks
