Editable quick reference guides
Michel Tosu
At work i'm responsible for our customer training on the Teleprecense equipment we sell. We always give our customers a quick reference guide for the remote. Like theese:
http://www.cisco.com/en/US/products/ps11386/products_user_guide_list.html
However i would like to edit theese in indesign with the correct fonts and so on. But i cannot find the resources, that would be a very valuable resource for us as partners to Cisco. We would for example like to add our contact information in the same font as the rest of the text and i would also like to edit some of the information boxes to fit some more useful information than the original. I would also like to translate it into Swedish.
I wonder if there is any link to that kind of resources on the Cisco website or if there is any other way to get a hold of those files needed?
Paula Talamo
Michel,
These files can be requested and you have been contacted offline by the person who can provide these.
Thank you!
Paula Talamo
5 Replies 5
Paula Talamo
Michel,
Thank you!
Paula Talamo
Paula,
Could I be provided with the same documents too.
Thank you,
Justin
Thank you,
Justin Ferello
Technical Support Specialist, ScanSource KBZ
Hi Justin,
I have forwarded your request and you should be contacted through email.
Thank you,
Paula Talamo
Paula,
I have not heard from anyone on this, can you check for an update please.
Justin
Thank you,
Justin Ferello
Hi Justin,
Please check the PM I sent you.
Paula
