Enabling AGC burden CPU load?
Hi all,
We are planning to develop a web based scheduling system for MSE8510.
In that system, we will enable AGC for every single conference room automatically using MCU's API.
Will this burden CPU load of the MCU too much if some conferences come to have about 80 participants?
Has anyone ever tried this?
Best Regards,
Kotaro Hashimoto
Martin Koch
Hi Kotaro!
Never tried that. Do you have so many issues regards audio?
Guess regards the number of participants it might be worth to know if you want to run the MCU in sd/nHd
or as a 2-/3-x cluster with additional audio only ports.
There are ways to generate sip audio and also video traffic if you want to test that. A consultant with some
sip knowledge will be able to help you there if you do not get a better answer.
