Events from Touch 10 user interfaces
marcogarzetti
I'm configuring a Cisco Touch 10 custom interface (made with the editor) that interacts with a control system connected to the endpoint. I subscribe to the events by using the command
xfeedback register event/UserInterface/Extensions/Widget/
and everything works great (buttons, sliderts, texts, spinner...), I receive every feedback from every widget correctly to the control system.
The only thing that I can't make it work is the "action" button. According to the Editor, a Panel without any page can be used as an action button, but if I leave the panel without any page, it doesn't generate any event when I press the button, while a panel with a page generates the page opened event straight away when clicked:
*e UserInterface Extensions Event PageOpened PageId: "IDdisp_pg"\x0D\x0A
Do you have any suggestion?
Thank you!
Marco
0 Replies 0
