EX90 inTouch Customization
davidguillory
Any customization for the inTouch panels? It is hard for me to believe that there isn't any way to customize this panel. This piece of the CI seems very limited especially when trying to customize for your executive staff. Costly tool- lots of limitations...
Nico Teunissen
The Cisco Touch contoller is designed to operate the C-series and EX series based endpoints. One of the main goals is to make the operation of the system as easy as possible. This creates a user friendly solution even for non-technical users. All TelePresence solutions will have the same GUI in the near future.
As far as I know there is no plan to customise this panel with additional control features other than the endpoint itself. If you are seeking for a solution that can operate multiple devices you might want to consider a Crestron or Amx panel. We support those solutions through our developer pages.
http://developer.tandberg.com/web/guest/integrator-modules/amx-codec-c60c90
http://developer.tandberg.com/web/guest/integrator-modules/crestron-codec-c60c90
