Factory Reset WebEx Room Kit
M44845
I am trying to factory reset a WebEx Room Kit. However, I do not have the admin password and the factory reset button seems to be broken (no button is preset when I put a paperclip in the reset hole).
Is there any way to reset this unit?
Does the plastic cover come off so I can try to find the factory reset button?
Thanks!
Matt
Wayne DeNardi
You need to be careful when inserting the paperclip and make sure you have it at the right angle.  If a paperclip isn't working for you, try using a small screwdriver or something a little fatter that may be less likely to miss the button.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
