H.323 Sound Issues
Rod.Blackie
I've a strange problem.
we have a c20 system that is registered to a vcs-c running 7.2 we have a firewall (palo alto) and a vcs-e that sits on the internet. We have one ACL rule from the vcs-c to vcs-e to permit any traffic. This seems a standard set up.
When we call a remote MXP 95 system via the interent (this system is registered to a vcs-c running 7.1) using H.323 at least 90% of the time we hear no audio.
When we place the same call to the same system using SIP there is never any problems - audio and video work.
The remote system calls our system using H.323 with no problems.
Anyone any ideas how to help with the sound issues?
Rod
8 Replies 8
Martin Koch
Check that there are no h323 awareness/ ALG /nat helper/... enabled in the firewall and that all needed ports are open
that also counts for the remote site.
Nachricht geändert durch Martin Koch: just underlined / made some word bold, ...
Hi Martin
As far as I know the Palo Alto firewall has support for H.323 and no additional configuration is required.
I think my problem might be because my VCS-C speaks to my VCS-E using PAT which isn't handling the inbound voice traffic? is this something you've or anyone else has come accross?
Rod
Thats the wrong thought, as your firewall has h323 support it is bad and has to be disabled!
The VCSs have to relay on what they send and receive, if some device thinks its more clever and mangles with
the signaling it will break communication and cause strange symptoms like you experience now.
Disable the h323 features on the firewall and allow the required communication - see vcs admin guide as well as the firewall guide:
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_IP_Port_Usage_for_Firewall_Traversal_Deployment_Guide_X7-2.pdf
Martin,
Thanks for the reply.
Our VCS-E does not have any firewall between it and the internet. The VCS-E sits on a public IP address. All calls to and from the VCS-E to the internet do not have any firewall traversal.
Our VCS-C sits on our inside network and connects via the firewall to the public facing VCS-E allowing all ports from the VCS-C to the VCS-E
I meant the firewall supports H.323 - its not like cisco kit with fixup inspeciton - by default no inspection is applied to H.323 traffic.
Rod
You know, I just googled: palo alto nat h323
and the first hit I got was this document:
http://media.paloaltonetworks.com/documents/whats-new.pdf
Quote:
  • H.323 ALG Enhancements – The H.323 VoIP application-level gateway (ALG) has been enhanced to support dynamic prediction of media sessions (pinhole opening) based on the signaling data, as well as payload modification when performing address translation on the traffic allowing NAT/PAT traversal for H.323 VoIP traffic.
no further comment
Hi Martin
Don't you think the PA marketing gimmick is correct re how they deal with H.323?
I will figure out how to deactivate this feature and let you know if its successful
Thanks for your input so far.
Martin
You were correct. The PA firewall application inspection was the cause of the problem. To resolve the issue I created an application override policy on the firewall for all the H.323 ports for vcs-c to vcs-e communication. This stopped the application inspection and the sound problems dissapered.
Thanks again for pointing me in the right direction.
Rod
Rod, I believe we are having the same issue. Can you explain to me how you did the application override?
