03-05-2015 11:14 PM - edited 03-18-2019 04:09 AM
I need to add following licenses on expressway (EXPWY-E-K9).
1. LIC-VCS-10+ - Video Comm Server 10 Add Non-traversal Network Calls
2. LIC-VCSE-5+ - Video Communication Server - 5 Traversal Calls
In datasheet it says N/A against these licenses. Can someone please suggest the solution to add these licenses.
Thank you.
03-08-2015 06:55 PM
What do you have, a VCS-Expressway, or are you searching for licenses for Expressway (Edge / Core)?
The VCS is the older style of video deployment, the Expressway is the newer CUCM only based setup.
The VCS had the LIC-VCS licenenses for Calls,
Expressway has: LIC-EXP-RMS
Ordering Options for Cisco Expressway Series | |
Cisco Expressway Rich Media Session License | LIC-EXP-RMS |
(Required for concurrent calls to/from any endpoint or application not registered to Cisco Unified Communications Manager. For example, Business to Business Calls, Cisco Collaboration Meeting Rooms, Jabber Guest and for | |
interworked calls e.g. H.323 to SIP, H.264 AVC to H.264 SVC) | |
03-09-2015 10:13 PM
It's a new deployment.
I just wanted to make sure that in VCS, if we needed 10 non-traversal call licenses, we had a pack for that (LIC-VCS-10+) or for traversal calls (LIC-VCSE-5+).
But in expressway, I do not see separate part numbers for traversal/non-traversal calls. and secondly, is this license per session?
03-10-2015 03:15 AM
The licensing model is different, with the CUWL licensing you get the expressway for free.
Calls for clients registered to CUCM (so to say the local calls) are included and all traversal
calls would be the RMS licenses you need.
You always need RMS on the Expressway -E and -C.
Just check with your Cisco Partner or contact directly regards pricing
