How to bypass the setup wizard remotely on CE8.2
I'm performing a VCS to CUCM migration and as part of the process, I'm factory resetting all the endpoints and upgrading to CE8.2.1.
My issue is that even once I've performed all the steps and have the endpoint registered on CUCM, the first time setup wizard still appears on the unit and I can't figure out how to bypass it without being physically present at the unit (which isn't an option as most of the units are off site).
Is there a command or web interface option to bypass the wizard?
Patrick Sparkman
Using the web interface, try "RunStartupWizard" under Setup > Configuration > Experimental, that is the only configuration/command I can find that relates to the startup wizard.  If it doesn't work, maybe try to restart the endpoint after you configure it for CUCM.
Patrick Sparkman
Thanks Patrick, that did it :)
