How To check TMS 14.6 Serial Number
Sushant Sharma
Hi ,
Please reply
bottom right corner ?
12 Replies 12
Hi Oleksandr,
Thanks i know but i am not using TMS appliance
Please check the screenshot.
Have you purchased TMS, and have a release key for it?  Is this an existing install, or new?
You're currently running a trial version of TMS, you won't see an actual serial number until you purchase TMS and enter a release key to fully activate the product.
Hi Patrick,
I am going for migration of appliance to virtual , i already opened a cisco tac  with licensing team for this . But they asking for Serial Number Of TMS Virtual Server.
As Oleksandr has mentioned below, you will be presented with a serial number for the new virtual TMS after you enter a release key.  To get a release key for the virtal TMS, you'll need to purchase it.  Refer to tms-appliance-vm-upgrade thread for more details.
Hi All,
Thanks for Help
Now it working . i can able to see the Serial Number
I have same problem with new sýtem TMS. Pls help me.
Did you purchase TMS and get a release key? After you apply the release key, TRIAL will change to the serial number assigned by Cisco.
I am not sure. What is th part number for tms release key?
The part number is CTI-TMS-SW-K9.  To see all ordering options, take a look at the TMS Data Sheet.
Thanks for support
Hi Sushant,
After you enter release key for TMS you will see serial number in bottom right corner
br Oleksandr
