How to Enable Cisco Meeting App for Internal Usage
mesut ozcan
Dear all,
CMS is deployed and integrated CUCM for VC calls. Now, CUCM registered devices can call CMS and join CMS hosted conferences succesfully.
Now, i want to activate Meeting App to use by local users only internally. What are required steps to achieve this goal?
As fas as i know, LDAP integration must be establish for this. But what are the login credentials?
Is there any other special steps for example?
Best Regards,
Mesut
Patrick Sparkman
You'll need to configure XMPP server, TURN server, and then LDAP to import users into CMS.  User will login with their email address and AD password.  All the steps are contained in the CMS Deployment Guides.
