When you set up the program, you can (or not) enable interactive "from the field" questions.
The client provide a button that can be pressed to flag the presenter that a field question is pending.
The presenter can then address the questions as possible.
Depending on the scope and location of the audience, you may also consider bringing up a conference bridge for voice-based questions.
Good Luck
Scott
