Interworking Altigen PBX with Cisco
Hello ,
Has anyone worked on getting a Altigen Alt Office 2 to interwork with the
cisco NMHDV12 Card.
Does the DNIS info get sent to the line if the controller is configured to
accept the line as a T1 or should it be a ISDN PRI T1 Interface.
I cant even get the card to talk to cisco.
The line does not even come up
Any help regarding this is greatly welcome
If any of you have doen this andhave a cheat sheet, it would be great if you can share it with me
Madhu
Chester Rieman
You will need to find out what type of signaling the altigen is doing on the T1, is it CAS or ISDN(PRI)? If cas, is it e&m or loop-start, if PRI what switch type.
Once you know this, configure the cisco gateway to match what the altigen is doing.
http://www.cisco.com/warp/public/788/signalling/signalling.shtml
