03-21-2017 09:22 AM - edited 03-18-2019 12:54 PM
I'm trying to set up LDAP for CMS client login and am stuck on the login ID. The LDAP sync part works great for creating users and spaces so far, but I'm not sure I'm following how best to set up the field mapping to get a successful login from any of the Meeting Apps (including WebRTC). the issue seems to be that our XMPP domain is cms.example.com but our AD\LDAP login domain is just example.com
So, I need to login as username@cms.example.com but not sure how that would then be sent to AD\LDAP in the correct form (username@example.com) for authentication. Any ideas on this? Is this about getting the JID correct?
thanks in advance
Steve
Solved! Go to Solution.
03-21-2017 10:16 AM
well, it looks like I gave up too soon. It indeed was related to the JID mapping and once I got the correct combination (by making it something like $sAMAccountName$@cms.example.com all worked fine
Steve
03-21-2017 10:16 AM
Steve
