IP Surveillance QoS configuration
burleyman
Level 8
Level 8
I am looking for some conformation / guidance on some QoS configuration.
I have attached a diagram of the network example for what I am looking to do.
I am looking at configuring QoS for IP Surveillance through a network. Now because the IP Camera I am using does not have a place to configure QoS DSCP settings I am doing it on the switchport. So I will set the CoS to 5 for that. Next I need to trust the CoS value on the trunk uplinks between the switches so I will configure those ports to Trust the CoS value. Next on the link to the server I will set the CoS value there just like I do on the IP Cameras for the video playback to the viewing stations. I was thinking I would need to set the CoS value on the ports connected to the Viewing stations but I am now thinking I do not need to do that because the traffic going to the station not coming from the station, am I correct in my thinking here?
I used this as a reference.
http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Video/IPVS/IPVS_DG/IPVS-DesignGuide/IPVSchap6.pdf
Here is what I am looking to configure.
IP Surveillance QOS setup
Enable QOS on IDF and MDF switches
config t
mls qos
Configure switchport for Camera
config t
int gix/x or gix/x/x
description IP Surveillance Camera
switchport mode access
switchport access vlan 45
mls qos cos 5
spanning-tree portfast
no shut
Configure trunk uplinks between switches
Do this on each side of the uplink.
config t
mls qos trust ip-precedence
Mike
Philip D'Ath
I would do exactly what you have done.
Great Thank you!
Go All Blacks!
Mike
One more configuration. For the servers where the video is stored and viewed from I was going to configure this. Goal of this is to give priority to traffic for the video viewing and mark that as CS5 and all other traffic like the control type traffic from the server marked as CS3.
class-map match-all VIEW_HTTP
   match access-group name HTTP
Policy-map NVR
   class VIEW_HTTP
      set dscp cs5
   class class-default
      set dscp cs3
ip access-list extended HTTP
   permit tcp any eq www any
Then on the interface where the server is connected.
interface gi1/0/1
   description NVR Server
   priority-queue out
   service-policy input NVR
Mike
Looks good to me.
