Lock Screen on DX80 CE8.2.2?
rfasiani
is lock screen supported on CE8.2.2 for DX80 on CUCM? (a PIN to unlock the device and place calls, not the PIN to access Settings or the PIN to access the web interface)
if not, when will it be?
Roberto Fasiani
Patrick Sparkman
The lock screen feature is not supported with CE software, only on Android.  You should contact your Account Manager and submit a feature request if this is something you're looking to be added.
