MCU Radvision Elite managed by TMS
s7pizzi
Hi all,
I need to understand if the TMS (last version) with Network Integration Extension (L-TMS-NETINT) supports the Radvision Elite 5230 MCU.
Thanks in advance.
kedang
As far as I know, there isn't any support for that model. I am unsure as to the roadmap.
The officially supported models for Radvision MCU are listed in the product support guide below:
http://www.tandberg.com/support/dl.php?id=867&dir=Application_Programmer_Interfaces&fn=TANDBERG%20Management%20Suite%2012.2%20Product%20Support%20Document.pdf
The listed models in this doc has been tested, verified, and documented.
Hope this helps.
BR
