Media Flow with VCS-E, VCS-C
gariusmar
We are planning to implement a VCS infrastructur now I`m not sure wich way that the media takes between the endpoints.
On the picture you could see the scenario.
Enpoint 1 is communicate with endpoint two.
1. Wich way takes the media stream ?
2. Is endpoint 1 communicate (media) only with the VCS - C and not directly with endpoint two ?
2. Do we have a directly connection between the two endpoints ?
Martin
Alok Jaiswal
Hi Martin,
the media would be flowed through the VCS control and expressway always in a traversal solution and use the traversal license.
endpoint 1 should be sending to VCS control and then it will be passed to expressway and then on to internet and not to the internet endpoint directly.
Rgds,
Alok
6 Replies 6
Alok Jaiswal
Hi Martin,
Rgds,
Alok
Hi Alok
Thanks for your answer.
Is that  like "media flow-through" with a cube ?
Martin
Hi Martin,
yes its a kind of the same scenario. but cube can't be replaced with VCS-Expressway.
Rgds,
Alok
Hi Alok
So do you mean i do need a cube in my scenario ?
I read a lot of documentation and also the designguide for VCS 7.2  but i never saw a cube.
Martin
Martin,
no no..cube is not required at all.
but there is a very common question you will see people asking like can they replace the cube with vcs-exp, since the cube also supports media flow through.
But there are other features like dns zone etc which can't be acheived thorugh cube and hence cube is not a replacement at all for the exp.
rgds,
Alok
Hi Alok
Thank`s for your answers, we will go forward to implement the VCS infrastructur very soon.
Best Regard`s
Martin
