Micrófono activo para codecs serie C ( C40 - C60)
raul navarro
Buenas tardes amigos
la pregunta es:
es posible transformar un Mic Table 20 de la serie SX para ser usado en un Codec C40?
la idea es que encienda el indicador del Mute (en rojo) y el indicadro de desbloqueo (verde)
o en el mejor de los casos si existe un mic para la serie C que haga lo mismo que el Mic de la serie SX
agradezco sus comentarios
Raúl Navarro
Wayne DeNardi
Hi Raúl,
No, it is not possible to use the SX20 table microphone, and keep the Mute function operational, on a C40.  The C40 uses a balanced XLR input which does not include any of the Mute functions, and there's no way to do it with a standard microphone.
You would need some external device to send API commands to the C40 or to replicate the IR commands for pressing the mute button on the remote.
As far as I am aware, there is nothing freely available on the market that does this out of the box.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Wayne DeNardi
Hi Raúl,
Wayne
Wayne
