Movi Call from Outisde to Inside-->Outside without Video and Sound
rasimyigit
Hi All,
since today, i have a problem with Movi Calls.
The Problem is, that Movi's from outside are registered about the VCS-E on the VCS C not build a picture or Sound.
The call is set up but I get no picture and sound. In the call history i got this Message on the VCS:
Subscriber absent Called party not registered
I never saw the failure Message.
The VCS-C/E Version is X.7.2.1, TMS Version is 13.2.1
Default Zone/ Default Subzone/ Traversall zone on Expressway is : do not check credentials
Default Zone/ Default Subzone/ Traversall zone on VCS-Control is: check credentials
The regestrations and Call buildung from Movis works fine but only without Sound/Video
Thanks for your feedback
rasimyigit
No ideas?
Check your firewalls
